So I shot some 50p on the F35 to an O7Q this weekend and I was working fast and when I plugged in both SDI cables for 50p I'm 99% I had it backwards - it looked fine on the odyssey from what I remember, but the DPX sequence that was recorded definitely has some funky issues. I think the interlacing is backwards or something? Or maybe the frames were recorded backwards (i.e. - 1 should be 2, and 2 should be 1, and so on)
Is there any easy fix? In after effects when I tried to deinterlace using upper or lower fields first I get CRAZY jitters.... should I try renaming the files? Any easy way to do this with like automator or something?
figured maybe someone ran into this before - and if anything else - ALWAYS MAKE SURE YOUR SDI CABLES ARE GOING TO THE RIGHT PLACE!
