50i or 60i setting help please
Petr Volgemut
I do not understand why SONY FS700 has only 25 fps and 50 fps setting option in Europe (50i), every cheap photo camera has also 24 fps and 30 fps even in Europe.
What is the difference between 24 nad 25 fps shooting (which is possible only in USA)?
What happenes if I set the camera to 60i in Europe?
I will also appreciate links to more detailed explanation.
Thank you very much, I can read the manual:)) My question was different:
why is it possible to set 24, 25, 60, 60 fps in US (60i) setting and only 25 and 50 fps in EU 50i setting? Why only 25 and 50 fps?
What is the reason? Every photo camera as Nicon, Canon, atc. have 24, 25, 30, 60 fps possibility even in EU, why not FS700?
I'm a bit curious about the 60i vs 50i thing as well. I live in USA and only have shot with 60i. But isn't one of the main reasons the voltage from the power sockets? If you shoot 50i in the USA or NTSC countries while using lights, you will get a flicker in your footage because our power is 60hz, and vice versa.
Not sure where I heard that from and I could be completely wrong.
You can change between 50 and 60 hz framerates in camera, but you'll have to change sd card too. I always have dedicated card for 60hz material and another one for 50hz. The biggest problem with FS700 and 60hz framerates in PAL area are shutterspeeds. When you set the FS700 in 60hz mode, you can't set shutter to 1/50, 1/100, 1/200 (50hz speeds...). Watch out for flicker...
