EVA1: 5.7K RAW Output Doesn't Work (Atomos)
filmguy123
SDI RAW OUT set to 5.7k RAW does not work when connected via SDI to the Atomos Shogun Inferno. The screen just displays green lines, no signal. This is when set to any codec, including ProRes RAW.
I am on latest firmware for both Atomos & EVA1, connected via 6G SDI. RAW in 4K Crop mode and 2.2K mix mode, including 240fps, works and records properly. But the screen just turns to garbage when set to 5.7K RAW.
I thought this was all officially enabled and supported per the latest firmwares?
It’s been said in almost every article that it’s not supported from start... I think I remember seeing “in about a month”thrown around... don’t have an EVA-1 so haven’t paid that much attention...
Ah! Thank you, I appreciate it. With all the info I must have missed it. I saw an interview with someone saying it was now supported only via ProRes RAW because there was previously no way to get it off, but I overlooked the later date for support.
The output from the camera works now, but the support by the recorder is coming in May.
Atomos Inferno recording capabilities from EVA1:
EVA1 RAW -> ProRes RAW HQ & ProRes RAW: 4K60p & 2K240p available now, 5.7K30p in May
EVA1 RAW -> CinemaDNG RAW: 4K30p & 2K120p
EVA1 RAW -> ProRes video & DNx video: 4K60p & 2K240p
EVA1 video -> 4K60p (over HDMI, 4K30p over SDI), HD60p
