smelni said:Its related to how we perceive motion - our eye requires 24 images per second to perceive motion properly - but 24 frames would introduce a flicker effect. To remove the flicker effect each image is shown twice to result in 48 frames per second.
pheboglobi said:They actually used to run film @ 16-20fps in camera prior to the advent of sound, which is what required the 24fps rate for the sound to run properly (since it was on the film itself). 16fps is pretty much the lowest limit for humans to perceive as continual motion. And for a long time, the standard rate for 8mm and Super8 (w/o sound) was 18fps.
I was under the impression that most modern projectors have 3 blades built into them, so they display 24fps films at 72Hz. That way it removes the slight flicker that occurs at 48Hz and it lets slightly more light pass through and it'll appear brighter. (There are even a few 5-bladed projectors floating around, and 16mm and 8mm projectors with 5 blades are often hot items on eBay.)
A fun trick to do is to turn your head so you are looking at a screen with your peripheral vision, and since your periphery vision is better at detecting motion than the center, you can often see the flicker if the flash rate is low enough.
Garrett
SPZ said:Garret, that means that an Image recorded at 50hzs could probably give the viewer a more "flickery"image than one recorded at 60hz, couldn't it?
