Depends on the camera and the aspect ratio. The AF100 uses an oversized 4/3 sensor with an active area of 17.8mm wide; Olympus 4/3 cameras use the 17.3mm standard sensor, so the field of view would not be exactly identical. It'd be close, but not identical.I dont have one to test so...
Does a 4/3 still camera (with interchangeable lens abilty) absolutely match the FOV etc as per the AF100 ?
Put another way. Could a 4/3 still camera be used as a directors view finder?
I would think two Panasonics would have the same field of view, but I'd have to test it.
