You will not see much difference until you do extensive grading where the benefits of 10bit kick in. There are plenty of examples comparing native codec and nanoflash recordings without grading on Vimeo using the Sony F3.
Did you think you were in the F3 forum when you posted? The AF is 8 bit not 10 bit and how is looking at the F3 footage going to help?
Personally I'd like to see some more full res frame grabs from shots with motion as there has been contradictory opinions on how much difference it makes, e.g. BBC Scotland saying "obvious softening on motion" with the on board codec.
You will not see much difference until you do extensive grading...
You actually do see a difference. I shot some Nano 280 Mbps stuff and compared it to the native codec a while back and the 280 Mbps 422 stuff has a deeper, richer, more saturated feel to it. That said I use the Native codec 99% of the time because it's good 99% of the time for the stuff I do. I'll reserve the Nano for green screen and projects that need a more cinematic feel.
I would love to see some graded comparisons too as that is probably the most useful. Ran into some serious blocking/banding today when I used some Magic Bullets (which I rarely) use on some AF native footage. It was a pretty deep look to it, but it certainly blocked out more than I expected. Definitely would have been interested to see it with Nano files too.
The Nano doesn't help with banding, it has the same 8-bit issues. I posted some files for someone here, Hywel I think, and he graded them both and said that a) he understood why so many people say that there isn't much of a difference, and b) the banding was the same in both.
I was using typical low-noise settings, so yes banding would have been more likely (in both). The more noise in the signal, the less banding will show up (in both). And Brian's observation is true that you can notice more noise in an external high-bitrate recording, because the AVCHD codec ignores some of the noise. And yes, I do agree that the AVCHD codec holds up better than XDCAM codecs so you might be able to squeeze a little more out of it in post. But you're not going to go yanking it up or down three stops' worth without seeing serious degradation, obviously.Like Barry said, banding is an 8-bit issue. That said my experience is the Nano does actually improve on the banding a little. This is because noise hides the banding, and the AVCHD codec hides the noise, hence more banding on the AVCHD footage. The SDI and HDMI output has more noise, but this noise is more pleasant to the eye than noise in the AVCHD codec which can become blocky. Bottom line is the way AVCHD 420 is set up; doing heavy grading means that noise is introduced which can become blocky and/or banding can become a problem. In my experience the AF100's AVCHD codec does hold up better than the XDCAM codec so light grading seems to be fine.
Agreed absolutely, and one of the reasons I have a Nano.As That's not to say one wouldn't benefit from external recording at a higher bitrate for other scenes. Clearly if one is doing chromakey one's first request would be to want 4:2:2 as a starting point, and motion-heavy scenes would probably benefit a lot more from an i-frame only codec.
For light-duty recording like headshots and interviews, I really pretty much defy anyone to see much of a noticeable difference, if at all, from an external recorder. If you're dealing with chroma keying you'll see a very big and very welcome improvement with the external recorder (as long as it's set to record 4:2:2; remember the Nano can be set to 18mbps or 35mbps mode and those are 4:2:0 so you'd never ever want to use those settings). If you're shooting high-motion high-action high-detail scenes, running through a forest with heavy backlight etc, then definitely the Nano at high bitrates will provide a noticeably sharper image than the onboard codec.But for the specific case in which I was experiencing banding, we concluded that an external recorder was not a panacea especially not at Nanoflash prices (the Ninja may be worth it purely as a dual-record/hardware ProRes transcoder leaving aside any benefits from 4:2:2 straight off the camera).
Sometimes I feel like I'm doing the Atomos and Convergent guys a disservice, so let's be clear -- I love love love the Nano. I think it's great. But what I've been saying is that the improvement in image quality, vs. the price, vs. the performance of the native codec on the AF100... I just don't know that it's a necessary expenditure for most AF100 shooters. On an F3, it's a no-brainer -- get it. Duh. Absolutely. The relatively tiny cost, vs. the huge performance increase, is well worth it. But when someone is buying a $4700 body, which already offers a better codec, the amount of difference doesn't necessarily give you that much more bang for your buck.I decided to save my money and not buy an external recorder just yet after seeing the footage Barry sent me as I'm not convinced of the benefits for the footage I'm currently shooting.
