QuickHitRecord
Package includes:
| 1 x Cavision 3x3 Matte Box Package - Includes side and top flags, and "nuns knickers". | |
| 4 x Cavision 58mm Conical Step-up Ring with 85mm Outside Diameter - Allows lenses with a 58mm filter thread to engage directly with the matte box. The cone design helps to prevent vignetting. If you have lenses with a smaller filter thread, you can use step up rings to attach these. | |
| 1 x Cavision 85mm to 72mm Threaded Metal Deep Offset Step-Up Adapter Ring - For wide angle lenses with filter threads of 72mm (can be adapted with step rings). This gets the front element of the lens as close as possible to the filter to prevent vignetting. I've used it successfully with an 18mm lens on my 5D3 without vignetting. | |
| 6 x Cavision MBH3X3M 3x3 Metal Filter Tray - Much sturdier then the plastic filter trays. | |
| 1 x Cavision MBH3X4M 3x4 Metal Filter Tray - For using ND grad filters. | |
| 1 x LockCircle Slider Base with Support Mount (Y) - This allows the matte box to be mounted to rods, while allowing them to slide back and forth for lenses that extend when zooming or focusing. | |
| 1 x Schneider 4 x 4" Five Slot Filter Pouch - Fits four filter trays nicely for fast deployment. |
I have 325 transactions with 100% positive feedback on eBay, so buy with confidence!
