I am also curious about this. I have two other 970 batteries and they are not holding a charge like they used to. I go through all three in about 5 hours of shooting.
Sony changed the mounting a little, so some 3d party batteries that used to work ok with other Sony cams do not fit anymore. SWIT S-8972 do work, we just tested them, they fit fine and the camera accepts them electronically without a problem.
Be wary of the Watson's. I picked up two recently mainly to use w the 7q, I attached both to the plate and when I removed them (and I'm not sure what the proper term is) but the inner shield of the female part of the battery came off and was stuck on the male pin on the 7q...it happened on both of the batteries and unfortunately I didn't notice until the next time I was out in the field when I couldn't mount ANY batteries on the 7q. We got the shields off the pins and once back at the shop epoxied them back into the batteries...and since the they have held up.
Operationally they seem to work fine and hold a charge as long as their Sony counter parts...at least as of now, who knows in a years time though...but I knew that going in. They also don't communicate with the battery charger like the Sony's do. I use the Sony VCL 1BP which gives pretty nice battery status as they are charging but you get no feedback with the Watson's other than to say it's charged.
I use the Switronix Hypercore 98 Anton Bauer compatible batteries with Switronix D-Tap to FS700 dummy battery. Works great in powering both the FS700 and the Odyssey at the same time and provides counterbalance for handheld situations since I have it mounted on 15mm rods at the back of the camera.
I am using a NP-F990 on a baseplate to power my A7s.
It is rated at 10,400 mAh 74.9 Wh and last 10 times as long as the in-camera battery and much longer than the NP970.
I got it from bestbatt.com and will get another if the FS700 I plan to order can cut the poor/low light I have to shoot Video in.
