[FS: General] 3ft Kessler CineSlider w/Hard Travel Case
colemanfilm
I have a owned this 3ft Kessler CineSlider for two years and have loved using it for a wide range of uses. This 3ft Kessler CineSlider comes with a solid travel case that is great for travel and flying. This slider is in near perfect condition and a great value at $1,200.
I have all original information and parts including the factory custom case ($69.95).
THIS IS A LOCAL LA OR BAY AREA PICKUP ONLY AND CASH PAYMENT ONLY!
The Kessler CineSlider™ is a robust, yet portable camera slider for rigs weighing up to 80 lbs. Coming in three different sizes from 28.5" all the way up to 60.5", the CineSlider is a very portable solution to get quick and smooth dolly movements without having to transport a large dolly system. Best known for its drag control (much like drag on a fluid pan/tilt head), adjustable arc diameter crank handle and guarded side rails for the most versatility, this flagship product will handle anything you put on it.
3' Length
Length: 40.5 inches (102.9 cm)
Travel: 35.5 inches (90.2 cm)
Height: 4.62 inches (11.7 cm)
Width: 5.7 inches (14.47 cm)
Weight: 9 lbs. (4 kg)
Weight Capacity (center-mounted): 35 lbs. (15.9 kg)
Weight Capacity (fully supported): 80 lbs. (36.3 kg)
Rail Mounting Hole Sizes: 1/4"-20, 3/8"-16
Cart Mounting Hole Sizes: 1/4"-20, 3/8"-16, #8-32
Handle Arc Adjustment: 3 - 6 inches (7.6 - 15.2 cm)
