35mm Lens adapters
yellowcake
Ive been looking for a good adapter, and I've seen Letus, but I don't want a front mounted adapter. I want one that is housed between the body and the lens. Any good 35mm adapters that I should check out?
If I understand you correctly, what you are looking for are an adapter AND a relay lens. The only way to mount a 35mm adapter directly unto an HPX500 or any 2/3 inch camera would be with a 2/3 inch relay lens, attached to the adapter. (The PS tecknik Pro35 comes stamdard with the relay lens)
Letus' selling two 2/3 inch relay: the pro and the compact.
I used to have a Letus Ultimate + 2/3 inch compact relay. It worked very well with the hpx500.
The Letus 35mm adapters and 2/3" relay lenses are on sale currently. I have used both the B4 Compact and B4 Pro with the Ultimate and own the Pro. Both will offer good quality at a price under $10K.
The Letus relays were designed and tested using an HPX500.
