30p FCP Problem
Bobby Comfort
Hey Guys and Gals. I recently shot a wedding in 30P Squeeze mode and it looked beautiful in the viewfinder. However, when I logged and captured into FCP the footage looked grainy, a little blurred, and worst of all, very interlaced. My capture presets are DV NTSC 48 kHz at 29.97 fps. Any help with this would be greatly appreciated.
Try this:
Set sequence settings->Field dominance to none
Then, right click on a 30p clip in the timeline, click item properties, find the field dominance field, click (maybe right-click) and hold, and select none
if it works... do that for EACH clip...
I've only seen this problem when mixing HD/SD or resizing 30p footage... but this usually works.
