[FS: General] 3-way custom-made XLR power tap
This is a custom-made power tap, with 4-pin XLR connectors. It will work with 10-15 volt power supplies, as well as any system that requires 4-pin termination.
I built this myself since there was nothing similar on the market. It allowed me to run several loads (camera, small light, etc.) on one large battery.
I found two small cast aluminum boxes, and had a machine shop cut out three holes on each for the Neutrik female panel connectors (you can see the holes in the top of the box, above, that I did not complete, in the above pic.. just to be clear, you would not be buying this unfinished piece, just the working tap, below). The pigtail on the finished box that I'm selling here has a Neutrik 4-pin male connector.
If you need to distribute the voltage from one power source to 2 or 3 loads, this is a perfect solution.
This tap was used only occasionally, and is still in excellent condition; I just checked it for continuity and shorts. Asking price is $75.
If you in or near NYC, you can inspect it, and take, cash-and-carry, from my UWS location (I'm a few blocks from 96th/B'way), or I will ship for additional charges and a PayPal prepayment.
I also have a 30-ft custom-made power cable for sale, at:
http://www.dvxuser.com/V6/showthread.php?261988
as well as...
http://www.dvxuser.com/V6/showthread.php?251455 (lav mic kit)
http://www.dvxuser.com/V6/showthread.php?252177 (shade for asphere, or ?)
Contact me here, or directly at marshall@mjeassoc.com
