Hi,
This is for playback of a fireworks show. The composite audio lives on the stereo pair and goes to the house public address system, and voice cues live on track three, and go to the director's and pyro crew's headsets. So I need at least three distinct playback outputs. The Roland R-26, as well as comparable units from Sony, Tascam, Edirol, etc. are all excellent recording devices, but again the problem is they don't have enough discrete analog outputs- Th Roland in fact only has headphone outputs. The problem with the Roland and the other contemporary multi-track standalone, is that they all generally mix down within the unit, providing only a stereo output. What I'm hoping to find is a reasonably (cheap) priced device that will output at least three completely iindependent, discrete channels. The only thing I've found is an analog/digital interface that has at least four output channels such as the Echo Gina, starting at around three hundred bucks. I found a legacy Gina, but it needs to interface to a desktop computer via PCI card. If I'm going to incorporate a PC, I need it to be a laptop,which means for me either USB or firewire interface. I'm hoping to find something either new or used, substantially inexpensive. It can either interface with a PC or be a "standalone" device. Even the old minidisc multi-track recorders would work, if they had discrete channel outputs instead of mixing down to a stereo output. In the meantime, Thank You for taking an interest in this quandary.....
(although I guess I don't remember if you could anything but the cue pulses on the cue track)
