View attachment 75031Here is sample of the moire that the 2k raw producess. This is a really serious issue hence the footage is flooded with this. 4k raw on the other hand is brilliant but for that i need way more storage space...
Indeed, which is why I think people would be best served to avoid the 2K raw for any purpose other than slow-mo. If you need raw, 4K is the only way to go, because that gives you the full sensor.This would suggest that Sony is line skipping to get to 2k over the full frame.
Probably from the 4k sony recorder I'd guess
Probably Odyssey 7Q will get similar moire in 2K
Image is out of this set up with cp.2 35mm superspeed. There is no moire in the 4k raw but 4k raw 50p takes about 20 gigs a minute so you end up running out of storage space pretty quickly.You are correct as far as raw goes. But the Odyssey has the additional capability of downsampling the 4K raw into a 2K or 1080p full-res HD signal. That would *not* be raw though, it'd be compressed video in something like DNxHD or ProRes. But it should also be alias and moire free.Correct me if i am wrong on this and they somehow down sample internally in Odyssey the 4k raw signal to 2k raw signal.
