countrymatters
Hi,
I bought Barry Green's HVX and HPX book and have copied the frame rate scene file to an SD card but have not been able to make it work in a 50Hz setting. The DVD that accompanies the book only has a single scene file in the frame rates folder and it would seem to be 59.94 Hz compatible only. Is this correct? How can I modify the scene file so that I can get the 2 FPS setting to work in 50Hz mode?
Thanks,
Andrew
Thanks,
Andrew
