[FS: General] $25 XLR mic adapter, Signvideo
Duke M.
http://cgi.ebay.com/Signvideo-XLR-P...581?pt=LH_DefaultDomain_0&hash=item45f4dd5dbd
This is the low cost perfect electronic device to allow you to connect XLR microphones to video cameras with 1/8" stereo phone jacks, such as the HV20, HV30, HV40, FX1 and many others. (Note: does not provide phantom power.)
SignVideo XLR-Pro Dual Channel Adapter - add XLR audio inputs to your camcorder. Mounts under your camera. Convert your camera to accept professional XLR microphones. This popular XLR-PRO™ dual XLR adapter lets you feed professional XLR audio to your DV camcorder or any camcorder or DAT recorder that provides an audio 1/8" jack. This lets you use professional XLR microphones, tap into PA systems, and use long run, balanced audio cables, all with complete confidence.
Mix any two inputs
The original XLR-PRO™ XLR adapter lets you mix any two microphone inputs with ease using the combination of dual volume controls, dual XLR inputs and dual 1/8" inputs. Hook up two XLR microphones, or an XLR mic plus wireless mic, or any other combination of professional and prosumer mics. It's an XLR adapter and mini mixer.
Accident free audio level control knobs
The only XLR adapter knobs that are smooth and easy to adjust, but impossible to accidentally bump out of adjustment while shooting. The knobs simply won’t move unless you grip them and turn. This is especially important when mounting the XLR-PRO™ under your video camera, where knobs are easy to bump. And it’s all done without click stops.
All aluminum housing provides shielding from interference and more
Unshielded plastic enclosures for XLR adapters are an invitation to soundtrack havoc. That's why the XLR-PRO™ is enclosed in solid aluminum to protect the entire electrical circuit from interference which may otherwise destroy your valuable soundtrack (our transformer shielding protects from another kind of interference unrelated to the need for shielding the entire circuit). Plus the all metal enclosure improves grounding capability needed for many camcorders.
Quiet operation, shielded transformers
High performance multi-shielded transformers provide supremely quiet operation. In addition, the unique ground switch on the XLR-PRO™ lets you select the quietest ground for any camera (no floating ground). Not to be confused with "ground lift" switches which do not perform this important camcorder grounding function.
