DavidChia
I've recently sold my extra mounts and I had many email asking me about the clamp part. I can get you guys the clamp part with all the screw, nut, bolt and allen key( pictured as above, but will be in bare steel). It will cost 25 euros , buyer pays for actual shipping. you can purchase the Cinevate 15mm universal block yourself. The block cost $34 from Cinevate.
Note the part will be in bare steel.However it will still be rubber padded. Galvanized to make it black in color cost 5 euros more and 1 week extra. You can paint it black yourself or just leave it.
I use it for both my Letus and Brevis. By the way there is still no support that can clamp the Letus economy down except mine here.
Contact me at davidchiaemail@yahoo.com
Paypal only ( verified)
I can say that after owning the Original Brevis mount and Geardear lens mount and Cavision lens mount. I came up with this solution. The rubber paddings absolbs the vibration of the Brevis or the Letus and also grips the Lens .
I use it as a long lens support and also as my Brevis support. It is rubber padded so it does not scratch the Brevis , Letus or lenses and it is also height adjustable (45mm to 110mm measured from the top of the block to the centre of the lens). It is more then enough for matte box or follow focus unit.
The diameter of the clamp is between 75mm - 80mm but because of the rubber padding surrounding it . It clamps between 73mm - 78mm. Thus making it perfect to clamp even the Letus Economy (76mm) down on to rails .
It is fully lockable with an internal locking screw and nut I will also throw in a HEX key for the locking down of the screw.
And when you take the top piece up , it will work as a long lens support and cushion your lens and protect it from scratches.
The original Brevis clamp cost Canadian $135 + shipping + tax ) = over 100 euros
