This is my first time capturing and working with 24pA footage from the DVX100A. For recording, I set my camera to F6 on the dial (default settings) and checked to make sure it was 24pA in the Scene File.
Then, in FCP, I captured using the "DV NTSC 48 kHz Advanced (2:3:3:2) Pulldown Removal" preset. Strangely, the item properties in FCP show the clip as 29.97, but it shows up as 23.98 if I open it in QuickTime.
My sequence is set to "DV NTSC 48 kHz - 23.98." But when I drag the footage to the timeline, it asks me to change the sequence settings to match the clip.
If I click yes, it plays back smoothly but the sequence properties show it's been converted to 29.97.
If I click no, the sequence stays at 23.98 but the playback is jumpy as if the incorrect frames have been removed.
Any clue as to why this might be?
EDIT: Here's the solution.
It turns out the problem was caused by a timecode break. If I capture around the timecode break, it recognizes the clips as 23.98. Hopefully this might help anyone who encounters FCP falsely recognizing 23.98 footage as 29.97.
