24p slo mo problems
  • Start date Start date
G
Guest
Guest
Hi
Are there any issues with slowing down footage shot on a DVX100 24p or 24pA
Wollice
Re: 24p slo mo problems
24P is the worst format to try to slow down. You'll get much better results from slowing down 60i.
The smoothest slow-motion possible is to shoot your slow-mo segments in 30P, and then play them back at 80% speed on a 24P timeline. It's frame-for-frame accurate smooth slow motion, but not very slow.
You can get super-smooth slower slow motion by shooting 60i and playing it back at 40% speed on a 24P timeline.
Using other speeds (like 75% or whatever) will cause jitter and not be smooth.
Question for you guys. When doing slo mo you loose rez when you play back 60i @50%. On the other hand you get jumpy footage if you slow 30P down by 50%. This is well understood but...
Could you get what "60P" MIGHT look like (I know its not a regular format) if you used Twixtor on 30P footage to create inbetween frames making it 60 progressive frames? If so, can it be seen in that format under NTSC/DVD standards? If not and its forced to change to 60i do you gain anything by going thru the process v.s. shooting 60i in the first place?
[quote author=Barry_Green link=board=Events;num=1100056946;start=0#3 date=11/09/04 at 11:17:53]24P is the worst format to try to slow down. You'll get much better results from slowing down 60i.
Using other speeds (like 75% or whatever) will cause jitter and not be smooth.[/quote]
But would it be possible to mix both the 30P (if ya play it back on an 80% timeline) and the 24P footage togeather without any problems ?
--Bop
Firstly I'm no editor, but I shot some footage recently for a music video @ 24speed and the editor had no trouble with slowing it down (Avid suite) we could take it down to whatever speed, ramp it, stop frame it and it looks great.
[quote author=Thistlebop link=board=Events;num=1100056946;start=0#5 date=11/10/04 at 04:13:07]
--Bop[/quote]
Depends on your editing program. I do it in Vegas all the time.
