rjcam
I recorded 16 dv tapes in one week all at one setting, 24P regular, with an almost new DVX100b camera.
75% of footage is correct - *2:3 pulldown inserted and recorded footage. And digitized like it's supposed to at 60i and I can remove the pulldown easily with CineTools either automatically and setting 'A' frames on clips where the 'A' frame was off.
For no known reason about one quarter (50GB of 220GB total digitized) of footage has interlaced artifacts clearly visible in all frames in CineTools, and FCP 6.0.2 viewer at 100% size. That's EVERY frame, not 2 interlaced and 3 clean. ALL frames show interlace problems.
CineTools can't handle them and 'skips' them. If I manually set an 'A' frame and have used every preset in CineTools, the footage either looks roughly the same or worse overall, but every once in awhile a part of a clip will have 4-7 clean frames and 1 interlaced.
What gives?*
I thoroughly understand this workflow and pulldown removal etc... And mostly the process works logically.
But not this problem. Can the camera freak out and screw up this bad, mashing up / interlacing / messing up all frames, sometimes for 35 minutes straight on 1 tape and then record correct afterwards?
ANYONE ever seen this problem or heard of anything like this?
I originally digitized FW out of a Sony DSR-11 DVCAM deck all the footage. I tried to re-digitize the clips using my HVX200 Camera ( I don't own a 100b) and I got the same problems.
Samples, very short and small, but original 3:2 pulldown full res SD, corrected CineTools removed version of same file, and one really bad file with all the frames messed up are posted here below. They play automatically in my Safari and Firefox browser on Macs and you could also download them and view them locally (they are literally 6MB to 11MB size I think - small!)
Video Problem Samples posted here:
http://rjfilms.com/doc_samples/
What gives?*
