now I am a little confused. The camera is set to 720p/24 but the framerate is 60 (59.94) how does that work? The movements are quite normal.
Can that be converted to 24p?
I should deliver in 24 p only. Don't even know, how that happen.
As stated above. If you look on your HVX200 menu, scroll further down until you get to 720/24pN choice. It is one screen roll below the 720/24p. The N for being native. You just shot 720/59.94 even though your camera setting says 720/24p. It has the look of the "film look" etc. Are you recording on a p2 card or firestore? YOu can do a pulldown removal, if you wish to shoot on 24p Native. How do you plan to export your footage?
I shoot mostly on P2 card now, only when I run out of space, I use the firestore.
When I use the firestore, I set it to Quicktime PN and when I use the P 2 card, my setting is usually 720 P 24 PN.
Operation Type : Film Cam
Frame Rate 24 Frame
But when I look in the Clip Properties : it is DVCPRO HD 720p/60 and 59.94 fps.
I am suppose to deliver the clips with 720p/24 in Apple ProRes 422 HD.
Also the file size is almost twice as big as with 23.98 fps.
But those clips I shot in 23.98 fps, also show DVCPRO HD 720p/60!
