No love...not knowing this stuff doesn't mean you're and idiot. We all start somewhere...and this can be confusing stuff.
This is something you choose when you go into your EASY SETUPS for the project. Or, if you have FCP 6, the timeline settings will change automatically to match the footage, if you click OK to the message. But you should choose the Easy Setups before you even capture the footage.
I keep reading about 24p and 30p timelines in the DVX Book. Is that a specific setting, or if the video is shot in 24p then the timeline is a 24p timeline?
What you have to keep clear in your mind is when talking about the DVX 24p means the camera shot 24 progressive frames per second (ish) but when it went to tape it went at 29.97 frame per second with a simple cadence (google 3.2 and 2.3.3.2 cadence). 24p (when talking about the DVX) means you want to edit it in a 29.97 (30) fps timeline in FCP. If you shot 24pA that's different... still 24 progressive frames per second and 29.97 fps on tape, but it has an advanced cadence (ibid). That is meant to be edited on a 23.98 (24) frames per second timeline.
Timelines are neither 24p or 30p... they are 24 or 30 frames per second... or 23.98 and 29.97 actually-ish.
Confused?
CaptM
