GH2 24p "24H": 1/50 & 1/60 shutter comparisons
I was curious to see what this test would show, so here we go:
GH2 24p "24H" @ 1/50th second shutter:
GH2 24p "24H" @ 1/60th second shutter:
Both clips are approx. 15-sec. long. I re-wrapped the camera-original .MTS files to QuickTime .MOV files without recompression so more people can play/edit them.
Again, I'm not sure what the results "mean", but FWIW both the Vimeo-compressed and camera-original versions of the files play smoothly on my MacBook Pro 17 via QT & VLC.
Compare, contrast, discuss. Cheers.
Just out of curiousity what was your technique for the ReWrap? Is this an advisable method of bringing the MTS files in for post work?
I tried rewrap2m4v and that works pretty well for me so far...?
Just out of curiousity what was your technique for the ReWrap? Is this an advisable method of bringing the MTS files in for post work? I tried rewrap2m4v and that works pretty well for me so far...?
Hi Dan: I don't use rewrapped files for post work myself. Instead I use FCP's Log & Transfer feature to transcode the GH1/GH2 camera-original AVCHD .MTS files to ProRes LT QuickTime .MOV files.
Before I upload these small camera-original test clip files to Vimeo I rewrap the .MTS files to .MOV files for "easier" viewing. It's just for convenience, not a workflow recommendation.
One of the reasons I shot this little test was I've seen posts online where people say motion in DSLR video looked "bad" (or "not smooth", or "jerky").
This test was just a way to show that this is not necessarily the case.
One of the reasons I include the (rewrapped) camera-original files is so that folks can compare them to the more-compressed Vimeo versions. For example, in some cases Vimeo may have done a fine job of compressing the files, but an individual's browser, plugin, computer, GPU driver configuration may be producing undesirable results. Or, the video might look good in a browser, but lousy in VLC or the QT player on a particular machine.
At least with the camera-original files there's a small chance folks can figure what the camera is capable of vs. their hardware & software capabilities. YMMV.
I'll be honest I can't tell the difference and I think if you had gotten them mixed up you wouldn't be able to figure out which is which.
It's definitely noticeable to me, but just because you close your eyes doesn't mean the world disappears.
Look at the 1/60 clip... you can see the markings on the bottom of the turntable alternating 'black/grey'. On the 1/50 clip those are smooth. You could use a strobe light, those markings
and calibrate your turntable speed... but I digress...
