24 Frames at HVX200
Assuming you have a PAL HVX200 - no, you can only record 25 frames. If you do have a PAL camera then my first question would be why do you want to record 24 frames?
I have one doubt about that. You can shoot at 48 frames in the pal version, which is the double of 24. If u discard the half of frames.....
I should do some test, but maybe works...
... but it won't be an actual, legit 24. And you won't get sound if you shoot in 25pN mode @ 24fps. And 48fps isn't 48 frames per second either, it's something like 48.17 in the US version, and 48.08 in the European version.
