2 quick ex1 questions...
i just got my ex1... lovin it so far... 2 questins
1) I cannot figure out how to set white balance to 5500k... i can set it to 3200 and ATW, but cannot get it on 5500 for outdoor light.
2) Can you change the focal measurement to feet? mine seems to be in meters.
3) is there a wat to see a zoom measurement display in numbers lika on the hvx200?
ok so that was 3 questions...
thanks guys!!
thanks guys!!
#1 - you set the preset value through the picture profile button. Select one of the profiles, PP1 through PP6. Then in the SET menu choose White > Preset White to select a value from 2100 to 10,000
#2 - Menu LCD/VF SET > Display On/Off > Lens Info (in Meter or Feet)
#3 - Right below that one is Zoom Position (Bar or Number - 0 to 99)
Another option is to use Partial or Direct Menus, then the color temperature can be adjusted on-LCD with the joystick.
