Randall Ayers
1. Does it matter in which order the UV and Pol. lens filters are put on?
2. I set the AWB switch to 'Prst' and I know when you push the AWB button in front it is suppose to change from 3.5k to 5.6k (or whatever the numbers are). When I push the button i see no change at all in the look and NOTHING shows up on the LCD.. All it says is 'AWB' in the middle of the screen for 3-5 seconds and then shows 'AWB' on the right side of the LCD... is this normal or should it actually say weather it's on the 3.5k or 5.6k ...
I did searches for this but found nothing so I'm sorry if it's a duplicate question.. Thanks for the help
