My current setup for a 2 person sit down interview is to use two laves, one a Sony EMC-44B, the other a Sennheiser AVX-ME 2. Yes, one is wired the other is wireless, but that's what I got. I also boom a Rode NTG-3 at the main speaker. I could set up a second boom mic for the second speaker, but I never have. It would be a Rode NTG-2.
Now this just happens to be what I've acquired over the years, definitely not the most ideal. I'd like to step it out a notch and looking for suggestions. My main issues is in isolating the two speakers.
Some thoughts:
- Generally with 1 person interviews, I usually end up using the boom, as it usually sounds better. But in a two person interview, each mic would pick up the other speaker and echo. So I don't end up using it.
- I prefer wired lav mics for sit-downs, but I'm not sure that the Sony is better then the Sennheiser. I might give a little edge to the Sony in some tests I've done.
- When the speaker on the Seinnheiser is talking, I hear a lot more echo, though I think this is mostly due to the slight latency in the wireless, setting the two mics slightly out of sync. At the same time, I also suspect that the Seinnheiser does a better job at isolating just the speaker that is mic'ed, while the Sony seems to pick up more of everything. The isolation is better.
- Should I be using two boomed cardioid mic's for this type of work? (some thing like the Rode NT5? Which comes in a set of 2?)
Thanks any suggestions would be helpful.
Some thoughts:
