FS7: 2 Days with the Sony PXW-FS7: Early Impressions
basspig
My perspective comes from the context of having used the PMW-EX1/3 cameras for several years, so bear that in mind as you read my comments.
The first few hours with this camera were a panic frenzy to try to understand the controls enough to get meaningful output. Even having spent days in advance of the purchase, studying the relatively useless manual (it really doesn't tell you WHAT a control or feature does, just "turn on such in such to activate the blah blah feature") we all know about that. Largely, the manual is a list of features. But.. it's also out of date with the new firmware and needs to be updated to reflect the current feature set.
As many of you (painfully) know, I have stringent audio requirements for my cameras. Every camera must pass a proof of performance before being put into service. I tested audio two ways. First, I bench-tested the camera, using a Tektronix SG-5010 Programmable Oscillator, with a balanced output, driving the input of the FS7's mic channels. I monitored the headphone output on a Tektronix 2465B oscilloscope and Tektronix AA-501 Distortion Analyzer. I discovered that the headphone output clips at less than 2 volts peak to peak, which is about 775mV RMS. High efficiency cans are a must.
On the sweep test, I set the Distortion Analyzer to read relative levels and set '0' at 1KHz. I have the oscillator programmed to sweep 20-20,000Hz and triggered the sweep. I noted that at 20Hz, the mic preamps through the headphone jack were down 7.4dB. A 1KHz square wave had quite a bit of tilt, albeit very little overshoot. The DAC and decimation filters indicate high quality performance. At this point, I suspected that the headphone amp was responsible for the bass rolloff. So, on to the RMAA test. Before I go further, I will relate my findings about gain-staging. I wanted to find out where the overload level is for this preamp. I set the Ref level to -40dB and ramped up the input signal from -40dBm, slowly, finding along the way that the headphone level had to be reduced several times as it was clipping and not the mic preamp. I got all the way to -3.95dBm until the mic preamp clipped. This is respectable performance. A condenser mic would have to be in front of something very loud to approach that level, and it probably would clip internally anyway. No worries about handling loud signals. Oh, and the dial setting for that level is what I would describe as '3.1', or a sliver past '3' on the dials. Below that, and you're not lowering the noise floor any further, but you are limiting the top end headroom. In other words, this is the optimum level (compare that the 2000 ISO being the optimum level for S-Log 3 where you get the full 14 F-stops).
In the studio, I connected the output of a MOTU 896 Mk III to the mic inputs of the FS7 and played the reference tones and then the RMAA test signal and recorded it. Downloaded to Premiere, exported a wav file and analyzed the result with RMAA. So the mic pre is the source of the rolloff, not the headphone amp.
To be sure, I also checked the Line Input mode. That was as flat as any decent studio DAC. More interesting, is the s/n and dynamic range are as good as many studio DACs. As such, a corrected EQ in post to lift 7dB @20Hz could work, as the noise floor is way down in the absurd range and some boost won't cause any electrical rumble. I'm pondering building a passive network to attenuate everything above 20Hz with a knee at 200Hz, by 7dB, so that I don't have to do this in post every time. Another possibility is to buy a phantom powered preamp that can mount on the camera. Another item hanging off this already immense camera. Okay, enough on audio.
Ergonomics.. the hand grip fits nicely, but as a shoulder cam, it's awkward. This camera will need to be rigged to make it comfortable and balanced. Needs a quick release plate and a shoulder pad. I have some articles by Allistair Chapman with some proven rigs that I'll put on my shopping list.
Operation: First day, I felt like a fish out of water. I don't know where ANYTHING is! Fumbling is the operative word. Good thing I didn't have a gig to do within the first week. This camera has a steep learning curve. There are some familiar things that EX users will recognize, but there are things that aren't the same--no picture profiles to be found. It appears that one saves and loads looks from SD card. But I have a lot of testing to do to find out just WHAT gets saved to the SD card.
Of course the big deal is S-Log. S-Log 2 is clean as a whistle and relatively easy to grade. S-Log 3 can bring out some noise if the exposure isn't through the roof (looks completely blown out in the VF), so the uninitiated will under expose and screw up the first few shots. I was surprised that some footage I shot today that looked like throw away, looked fine in post after applying a reverse curve.
Light sensitivity: A word: wow! Even with the F4 28-135 Sony G lens. Way more light sensitivity than the EX3 with a F 1.9 lens. I can't imagine an F.95 lens on this sensor. ND64 is barely enough with F8 aperture in daylight. Filming in low light, the details and the bokeh are both creamy and noise-free. Convenient feature over the EX line: shutter speed may be completely controlled without switching shutter to a special mode. If you're filming by moonlight, and you need more light without increasing the gain, it's easy to dial down the shutter speed (works in speed, not degrees mode) into subdivisions of the frame rate.
The 28-135 Lens: Okay, it IS a limited range, and is still tunnel vision on the 'wide' end. It's a slow lens being F4, too. Differential focus will not be as good as a F1.4 lens, obviously, nor will the light gathering (but light is no problem with this sensor! F11 indoors at night under LED lighting!) Yes, I'd like a wider lens. And one with more zoom. But this was okay on the outdoor soccer field and was perfect for filming kite flying.
Want to know what's GOOD about this lens? The image quality. It's simply the BEST lens I own at this time. This is the first lens that doesn't have any visible chromatic aberration. And it's sharp from corner to corner. The ultimate test for CA is filming up through the trees to overcast sky. Other lenses are horrid in this regard, with 2-3 pixels of red/green fringing. Not this lens. I had to look again and again. It's not there. The images are in a different league from the Fujinon lenses, which themselves are very good.
S&Q: As my Premiere CS6 won't do XAVC, I fortunately have a Atomos Shogun that writes a compatible file. I mostly record on the Shogun off the HDMI port. For S&Q, I record the high frame rate to XAVC and then play it back at 24FPS to the Shogun, where it gets recorded and converted to ProRes. That works. The YT clip above has insets of video at 180FPS played at 23.976. From what I can tell, the image quality is very good.
There are numerous mysteries yet to uncover. One is how to get the scopes to display. An article I was reading tonight said that they only work when LUTs are active, but I don't know which LUTs or where they need to be applied to get past 'cannot proceed' when the scopes attempt to be accessed. Another mystery is what replaced Picture Profiles, and what type of file stores that kind of information to the SD cards.
I need to get some wide angle lenses for indoor shooting. I'm looking at Rokinon lenses from 10 to 14mm. Many of excellent reviews by their owners. I'll also look at some cine primes. And I really could use a zoom that goes wider, but is as clean and free of distortions as this Sony G lens. What an amazing lens.
Rails, matte box, quick release, shoulder rig.. all necessary items. As configured from stock, there's no proper way to set this thing down on a flat surface. And that grip handle has to be removed and re mounted in the opposite direction to slide the cam onto a tripod head. These things can be fixed with accessories, so I'm not too concerned.
My decision to buy a Shogun recorder last March proved to be the right one, as it's been the savior that lets me get 2160P into the editor. NVENC plugin and nVidia GPU with 1536 CUDA cores makes it possible to work with the footage and to render out 2160P videos for Youtube in reasonable time. I can't imagine doing the renders in software.
In conclusion, I think the FS7 is a keeper. The picture is amazing. Especially if the scene is halfway decently exposed. The images on my DCI 4K monitor look like you can just reach through the bezel and touch them. The dynamic range is such that I find myself turning the monitor backlight all the way up to 100, where the forest floor is nicely lit, and when the camera pans up to the sky, you have to squint, it's so bright. Yup, the way to enjoy some of those 14 F-stops is to turn the backlight all the way up, so the darker parts of the scene come out of the black. It's amazingly clean, still. And I'm sure the shooting can be optimized way further than my early experimental shots.
Dear Mark and/or Mary ,
It's gratifying you finally made the plunge and are happy with the FS7.
Any chance you could simplify your conclusions about the audio System for those of us who are not audio geeks ?
It was one scary plunge, that is for sure, but the more I use it and the more I get a sense of how to control the results, the more I'm liking it. My main problem is that everything I record has to go to the Atomos Shogun, as I cannot import XAVC in Premiere CS6. The Shogun literally saved me here. I CAN import and edit ProRes. And it looks VERY nice.
The audio... simplified:
The noise floor is so low as to be nonexistent. You never have to worry about setting your levels too low. You can always bring them up in post and you won't get any hiss or noise.
For 95% of users, the bass response won't be a problem. Especially if your studio monitors are NS-10s. :)
You can 'fix' it in post by adding an EQ curve with 7.4dB lift at 20Hz and the turnover at 200Hz. Or you can use an external mixer and go in through the line level jacks.
WRT mic level setting, a dial setting of just slightly above '3' is the audio equivalent of using ISO2000 in S-Log 3. It's the point at which the noise floor and the clipping level are aligned perfectly. Granted, for normal sound levels, this will produce inaudible results and will need "grading" in post to bring the levels up to broadcast values. One can ride the mic gains the traditional way, but with powerful NLEs and realtime audio processing, that's not necessary. Okay, if you're handing off the clips to an editor who expects customary reference levels, then do as required.
Thanks,
Have you looked at Sony Catalyst Browse? Free and Very easy to transcode to ProRes with it in post. Much easier than hassling with an extra recorder on set. Also an easy way to delog. I use it just for testing Log exposure as well.
Also did you try using the headphone limiter? That seemed to gibe me proper levels on phones. I have no idea what it does of course.
Last time I looked you say audiophile quality or something similar on your website. You do realize that a true audiophile would not consider something recorded to a video camera as audiophile quality? Measurements aside, you probably know that there is almost no way the AD is much more than a $2 IC. And the mic preamps are likely some cheap chip based units.
I do appreciate your review and testing. You think they rolled off the bass as a rumble type filter? And you mentioed one of the other things I was going to say, you should be able to easily EQ the rolloff out.
Take it EZ,
Robert
Thanks,
Again, If one uses Resolve one can reconnect to the camera originals after the edit. Thus eliminating a generation loss. As y'all probably know, Resolve Lite is free and can output up to UHD image sizes.
Robert
Lenilenapi, I tried Sony Catalyst Browse on two machines. On the slower office PC, it loads and sorta works.. it will encode to about 5% and then stop. After several attempts, I did get it to encode an 18 second XAVC clip. It took almost five minutes to transcode to h.264.
On my higher powered editing PC, the UI loads up to a point, but the program is completely non-functional. That machine is not connected to any networks, so I suspect it's missing something from the 'Cloud' that makes it complete and operational.
The bass rolloff is not a rumble filter. There is a separate switchable wind filter for that purpose. It's a mystery. It could be one of those "we take away a feature to protect our higher end models" kind of thing. The F55 probably doesn't have this rolloff, as neither does my EX3.
infohou: DACs are pretty good these days, and there are a few basic types. I can only report on test results, not how much Sony paid for the chips used. As for the inputs, aside from the rolloff, I'd say it compares favorably to mid-range studio quality gear like M-Audio Delta. The square wave response was surprisingly well-damped, despite the upper frequency rolloff being so sharp and little attenuation at 20KHz. From a Line Input perspective, the audio system is as good, or superior to some of the studio gear I've tested over the years. The noise floor readings were so low I had to double check that I didn't have the A-weighting filter engages on my distortion analyzer. Where I found it is possible to hear a difference between DACs is in the dynamics, because the accuracy of the stepping between bit sample levels varies between DACs. The only 'flaw' in this particular camera audio system is the LF response of the mic preamp. I wonder if that could be fixed in firmware. These things are usually achieved with DSP.
In other words:
All political/world-view commentary aside, his audio knowledge is on another level and FS7 pre-amps are damn good thanks to modern DAC/pre-amp tech. :)
It's possible that the PC version of Catalyst Browse doesn't work as well as the MAC version. Come over from the dark side and join the rest of us in the happy Apple world.:happy:
Thanks Benjaminreese for the good words. Folks here may not be aware that my other profession is in the audio industry. Decades in commercial broadcast audio processor design, broadcast engineering career up to retirement, and presently running Amplifier Experts, a shop where I repair everything from audiophile amplifiers to musical instrument amps. In 1963, I designed an output transformerless vacuum tube amplifier with three 6080 triodes. I love audio, and am "curator" of the Bass Pig's Lair, home of one of the most amazing custom sound systems in the world. Google is your friend. :)
Catalyst on my office PC is hit & miss. Sometimes it works, most of the time it stops rendering at 5%. But it doesn't use the GPU for rendering, only playback, so transcoding progresses at a glacial speed. 18 seconds of XAVC-I DCI 4K converted to h.264 takes 3+ minutes to convert. Not going to be useful for those 100-minute concerts.
Today I am testing the MPEG422 capabilities of the camera. I ran into a glitch, with the camera unable to record after switching to MPEG422. Tried switching back to XAVC-I just to see if it was something I was doing wrong, and found I could not record there either. So I shut the camera off and Googled the problem. Came back 15 mins later and there was still an image in the VF but no status display. The switch was in the OFF position but the camera was still powered on. Had to remove battery to reset it.
What I noticed was that the 32GB XQD card showed 15 mins record time in XAVC-I. When I changed the format to MPEG422, the record time available didn't increase! But I was able to record (not locked out), for 3 seconds, then I got a media error. Switch to XAVC-I and records okay. I found that if I switch to XAVC-L first, and THEN to MPEG422, the available time changed to 64 mins and I was able to record without a media error. That was last night. Oddly, today when I tried going from XAVC-I to MPEG422 directly, the camera worked as expected. Glitchy performance is cause for concern.
I turned off the lens correction (had it on thinking it was the reason why I have such clean images free from CA) in order to use the monitor LUT in S-Log 3), but I see no CA or obvious distortions without it on the 28-135 G lens. Maybe it only corrects lateral barrel distortion and the lens is very clean of CA? If I don't need it, may as well keep it off. BTW, lens correction was ON last night when I had my problem with switching CODECs. Possibly related?
Shot some MPEG422 in low light and compared it to EX3 footage shot on Samurai ProRes 422. After getting used to the look of FS7 in HD, the EX3 reference footage shot in the same lighting conditions looks noisy. Furthermore, there is more mosquito noise in the ProRes EX3 footage than in the MPEG422 FS7 footage, which is the opposite of expected. I attribute that to the low noise of the FS7 simplifying the work that its CODEC has to do.
As I understand it, lens distortion correction is not a general tool. It is designed for Sony lenses that need specific correction such as the f4 18-105, and that correction is programmed into the lens. On that lens it mainly corrects pincushioning. That's the only lens I know of that uses it. Unfortunately as you've already discovered it also hogs processing power and incapacitates LUT's unless they are all on or off. Also can't be used with 4K or Hight speed.
<Stuff Removed>
M-Audio Delta is a low end audio interface.
Robert
In other words:
Understanding good sound is complicated. Measurements do not tell the whole story.
The analog circuitry is also in play, not just the AD/DAC. How the mic pre loads a particular mic can vary widely. Even how the gain is adjusted such as digital vs analog matters.
Take it EZ,
Robert
Broadcast and audiophile quality sound are usually two very different disciplines with different goals.
I have previously been to your site.
I would love to hear your OTL as I don't think I have ever heard one. For those curious, an output transformerless(OTL) tube amplifier is difficult to design unless you copy Futterman. The idea was conceived in the 30's and was not considered practically implemented until Futterman's in the 50's.
Take it EZ,
Robert
I'm of the school of thought that sound quality is an objectively-measurable attribute. We can measure linearity, spectral bandwidth, pulse response, transient intermodulation distortion, phase response and more.
There is a 'snake oil' audio world out there too that believes in things you can't measure, because they're not there. Stuff like Valhalla power cords for $2300, and cable lifters. :)
M-Audio is not expensive, but it performs pretty well. A few years ago, Ethan Winer did a public test, He recorded a live session on three DACs and put the wav files up for identification of the mystery DACs. We had to identify whether a Soundblaster, a M-Audio Delta or a Lavry were used. He argued that digital is digital and you can't hear the difference. I correctly identified all three. The SB was easy because of the hiss. The Delta had less dynamic impact. But it wasn't easy, and it was impossible to do on headphones. On my main custom built sound system, the differences popped out at me.
Video/Film folks have a very archaic way of recording sound. Very different from the audiophile methods. For decades, audio for video was just awful. It's only starting to change.
Loading of the mic impedance is pretty non critical for FET condenser mics. Only critical for Ribbon mics, but then you're using transfomers to step up the low Z of the ribbon. The most important thing is a good noise floor, and flat response. A rolled off bass response makes voices sound thin and music sound lacking.
A lot of earlier cameras had noisy preamps and some had awful frequency response (recalling the HVR-V1U). They've gotten a LOT better. Mic preamp aside, the Line level inputs perform very well. Far better than a Zoom H4, and better than many 'premium' computer sound cards.
My early OTL was a totem pole topology and ran off a transformerless power supply. In the years after the war, I was pretty broke and couldn't afford to buy the transformers to build a good high fidelity amplifier. So I looked at various tube plate load charts and noted that the 6080, used as pass tubes in power supplies, could have a low enough plate resistance to drive a speaker, if several were used in parallel. That was more than fifty years ago, and I've moved a couple of times since then, having to part with some things along the way. But not to worry, I'm working on a monster OTL amp now, with 12 Russian sweep tubes with 45W plate dissipation and low (80Ω) plate resistance. The power supply needs are complex, and a delay because of needing custom power transformers resulted. But I have most of the iron now, just need the time, which will come in late fall over the holidays. Hope to have it ready for the next B.A.S.S. meetup.
For some reason, the light sensitivity of my FS7 seems to be about 3 - 4 stops lower than usual in Cine EI mode S-Log 2. In a relatively dim lit room, I was able to get 90% whites at F4 with 1/3 sec shutter. Now I'm getting around 20% whites. There aren't many options in Cine EI, but I must have messed up something along the way by loading scene files the other evening.
I was testing out a Rokinon 12mm F2 prime for a couple of days, but changing back to the 28-135 should not have messed up some internal calibration. Only other thing I did was a black balance with the lens capped. But it is way darker now than I remember from my initial testing with the kit lens. There are so many variables on this camera, that it's quite possible I missed something. Could have sworn the ISO was supposed to be 2000, but 800 is shown in the VF now. But I didn't explicitly change it. Turning up the gain has no effect on the picture either. Somewhat confusing. Well, I'm going to go shoot a piano recital in 90 minutes. Hope all goes well.
Did you have a lut on with CineEI? Maybe you had changed your exposure index rating. That or left the ND on without realizing it. I had that happen once when in a hurry I had gone one short of clear when I though I had it on clear.
I suspect I have a LUT enabled somewhere, but not where I can find it. I only suspect so because the VF image gamma appears about the same as the image on my Shogun with a S-Log 2 LUT enabled. If I turn off Shogun's LUT, it's much brighter at the middle grey and shadows than the VF and less contrasty. But here's the mystery: MLUT is set to OFF. So are all the outputs and internal recording. Where else might it be enabled? Either this is some glitchy firmware or the menus are too numerous and have too many interdependencies.
Doug, that's interesting about the ISO. Even more strange is that when I check the menu, I see the top three gain settings showing 2000, 4000, 8000 ISO, but greyed out. Below that are adjustable gains at 800 1600 3200. For kicks, I tried setting these as the ones above. Didn't change the picture or what was coming out of the HDMI port at all. Scope on the Shogun never changed when I applied the new gains.
It seems that the only time Gain setting has any effect on the video that gets recorded or output from a port is when the camera is in Custom mode.
I went and filmed a piano recital this afternoon. It worked out well. We had a horrid backlight situation, as the Steinway was next to a huge window that was letting in the afternoon light. On top of that, a Luxo arm lamp with a tungsten bulb was over the white pages of sheet music, less than 6" away. So we had extreme bright light sources that were not the subject, plus a mix of color temps. Amazingly, the FS7 took it all in stride and the picture looked natural and cinematic (due to the differential focus). I was dealing with direct glare from a 100W lightbulb as well as the window glare, and any of my other lenses would have had red/green CA fringes 3-5 pixels wide at the edges of contrasting objects, but not a trace of it with the Sony G lens. It's only an F4 lens, but it's a clean lens. I wish I could find a zoom of this quality but in 18-105 or so.
