Matt Gottshalk
Resident Preditor
Comes with barn doors and scrims/scrim cases for each.
Has the equivalent output of a 650w fresnel
Mounting bracket upgraded to much more heavy duty mount.
Each comes with a ballast.
Bulb will be included but there is no guarantee that it will survive the shipping journey.
$385.00 each plus actual shipping to your location.
I will split the paypal fee with you if you choose that method of payment.
From the Cool Lights website:
The Cool Lights CL-MF0150 CDM (Ceramic Discharge Metalhalide) Fresnel is the perfect, portable, energy efficient, hard light compliment to our Softlight fluorescent series. Based on HQI/HCI 150w single ended, G12 type metal halide compatible quartz or ceramic long life bulbs (typically 6000 hours for the ceramic version and 2000 hours for the quartz type) CDM bulb. CDM is a cold start technology which requires waiting for about 5 minutes after extinguishing the fixture/bulb before relighting. This is the main difference between CDM technology and HMI. Otherwise, this has all the same characteristics of an HMI fresnel. Included ballast is whisper silent and flicker free. We often call CDM the "fluorescent of hard lights", because of its "cool light" output and same 4 to 1 power efficiency as fluorescent. Works well for all types of media production from still photography to video or film.
Great when you need that small and portable key or fill light for your setup. The physical size of the fresnel is the same as a typical compact tungsten 650w fresnel. Also, it's handy for projecting those cucaloris ("cookie") patterns on the wall behind a subject; or when you're using a gel to add some color to a setup, this unit provides all the light you need to make a powerful color streak or wash when using the barndoors and focusing knob in various combinations. Your subject will appreciate the fact that the light emanating from this unit is cool in temperature without the infrared component of a normal tungsten fixture. The fixture gets hot, but not as hot as a tungsten 650w fresnel--and since the light output is cool (temperature-wise) we still feel comfortable calling this a "Cool Light."
