~1GB ProRes HQ Sample of GH13 Footage, Shot with Contax G Lenses
marco0782
These are some samples from a feature I shot in September on my GH13 using 50mbps AVCHD with 24p enabled. Occasionally for deep focus shots with grass/foliage I had to switch to 60i to avoid freezing (such as the last shot in the video). I shot in Nostalgic mode with everything set around 0 except noise reduction which was set to -2. I also shot at ISO 100 and shutter 1/50 exclusively.
The Contax G lenses were mounted with Metabones adapters, allowing me to focus the lenses with a follow focus. Focusing was smooth most of the time and there were a few repeatability issues, but for the most part the trouble was worth it because the lenses are wonderful. Backfocus is incorrect using the Metabones adapters which is my theory behind the edge softness of the 21mm (used for the last shot). It didn't seem to be an issue on the other lenses, and there aren't focus distance markings anyway. I would like to warn that these adapters are incredibly tedious to mount to each lens. I spent about an hour and a half per lens, and for that reason I have an adapter for each.
Lenses used were 21mm f/2.8, 28mm f/2.8, 45mm f/2, 90mm f/2.8. These lenses aren't very fast but I don't find super shallow DOF conducive to capturing a performance in a low number of takes. Even with super speeds I would lean towards shooting at f/2.8 or smaller aperture.
These are not color corrected. I simply transcoded from AVCHD to ProRes HQ, matted down to the proper aspect ratio, and re-exported in ProRes HQ. Due to the large size of the file, I will have to pull the link down once my server's bandwidth is close to being exceeded.
http://www.marcocordero.com/gh13/gh13_prores.zip (~1GB .ZIP containing ProRes HQ .MOV)
I also have a set of the contax G, 45mm, 90mm and 28mm. They are wonderful lenses if you can live with terrible ergonomics. Even with the metabones adapter which is currently your best bet. After some practice I can get the adapter on in less then 2 minutes, but I also bought an adapter for each one of my lenses.
If I had to do it all over again I am not sure I would go with the G's. Maybe I should have just gotten some other zeiss glass that has a real focus ring. Having said that I have not seen another lens that can match the sharpness and contrast of the 45mm G. I am probobly going to strip down the set and do some serious modifications to them.
In my experience the G's are something that you really want to have.
I have heard of problems with using wide angle rangefinder lenses on digital cameras. Apparently because you didn't have to worry about a mirror like in a SLR, the designers of rangefinder lenses could put the rear element a lot closer to the film plane. For some reason this was not a problem with film but with digital sensors you will get semering. I have not seen this problem with my 28mm, and I got this info from the getdpi.com forum so it might be something to look into.
How does Pro Res work? I am seeing everybody talking about it and i have no idea how to use it. I have FCP and a gh13, but not getting the same filmic look. If anybody could please explain the best way to log and transfer, set up my timeline, and export than i would be soooooooooooo thankful!!
Change your preferences in Log and Transfer so it will encode in ProRes. It doesn't increase the quality; it just allows you to edit the footage more easily and adds negligible compression artifacts on top of what is there in the raw footage.
Marco
Thanks for all the comments. The main reason I posted was to promote this great little camera with some actual high bitrate footage. When I was first reading about the GH13, it took me a long time to find video other than Vimeo or YouTube samples whose compression masks some of the camera's attributes.
Marco
I experienced no 24p glitches other than it freezing within the first second or so of high-detail, deep focus foliage shots.
Just fantastic! I burned it to BD using Encore (although it shrank it to 133MB, not sure why?) and played it on my 50" TV...AMAZING. After watching it a few times, I began flicking over to other movies being broadcast and back again...and it just holds up so well. Beautifully done. Thank you for sharing.
How did you get the exposure just right? I've been finding the lack of moitoring incredibly frustrating and the LCD screen to not be a very accurate indicator of the correct exposure. I've hooked my gh13 up to a monitor and done the trick to get an SD "live preview", which helps a lot to practise your shots...but it cuts out as soon as you press record.
Any tips would be GREATLY appreciated.
THANKS AGAIN
And what is happening with the feature? Please keep us posted.
I exposed by using a light meter, and also by referring to the +/- exposure indicator on screen which indicates what the built-in meter thinks. You can always just hold a grey card in front of the camera and look at the exposure indicator, then compare that against what the light meter reads.
Since still lenses are not rated in T-stops, sometimes you can't rely on consistency between different lenses at the same stop, so it's good to check what the camera thinks in addition to the meter reading.
I did some tests in pre-production where I essentially bracketed using video, i.e. my meter read f/2.0 and I would shoot the same shot 1/3 of a stop under, neutral, then 1/3 over. I would then examine my results on the computer. When testing I discovered that ISO 100 on the GH13 was closer to ISO 200, though this may have been due to the Nostalgic mode gamma. This was a pleasant surprise indeed!
The feature is in post now. I'll post more footage soon.
I think it is in no small part the ability to get the rear element so close to the film plane/ sensor that makes these G lenses better than the C/Y Zeiss glass - they're easily on a par with PL mount Super-prime Zeiss lenses it seems. I owned a G2 with the 21, 28, 35, 45 and 90, but sold the whole lot to get my Canon 5D. Boy I wish I hadn't, as the value has rocketed up whilst my canon went down. Now I have a GH1 I do have some Contax C/Y Zeiss glass, and it is of course excellent, but those G lenses are just the schizz for Cinema work on a GH1/2 camera. The 16mm f8 would have rocked for that last shot too.
