You're taking the resolution down, but other than that it should hold up well. Any particular reason that you want to drop to 720?
What are you exporting the projects for? The internet? You really don't need to use the Best Quality setting if you're just exporting for the internet. The data rate will be too high to be of use (like 17mbps or higher).Here is the problem. I am creating 4-5 minute projects and when I export them from FCP they are easily over 1gb.
I am exporting using H.264 and the highest possible settings in quicktime conversion for the best quality. I do not want to lower the quality so I though about lowering the resolution?
Does anyone know exact settings I should use so I wont have files that are so huge and still maintain excellent quality?
I uploaded a 1080p clip to YouTube that I had restricted to 12mbps, and YouTube re-encoding the clip at around 6.5mbps.
Experiment using the Restricted Data Rate option until you find a balance between quality and size that you want.
Just changing the Quality setting from Best to High will dramatically reduce your file-size.
