SamEdwards
When I set the shutter to 180 degrees (in the 'display' menu, Sony!?) and switch to S&Q motion 240fps, the shutter doesn't stay at 180 degrees. Worse, it maxes out at 85 degrees, which I assume is based on the new frame rate and will make the footage appear choppy.
If you switch to shutter time, you can set it to 500, which is close to 480, which is what I want. (Or Auto, which I would never use).
What I really would like would be for 180 degrees to always be like a film camera, where a 180 degree shutter is open exactly half of the time of each frame, or double the framerate.
It's amazing that Sony could get something so basic wrong. It really prevents these cameras from being taken seriously.
Does anybody know where to report bugs to Sony? Has anybody had luck with reporting?
Thanks,
Sam
Thanks,
Sam
