When working in a 16:9 project, does the mojo give a correct aspect ratio on a 4:3 client monitor? Or do I have to connect a 16:9 monitor or 4:3 monitor with 16:9 setting to get a correct image, not squeesed?
You need to either connect a 16:9 monitor or 4:3 montor capable of correcting the anamporhic image.
You can create a 3D DVE that corrects the aspect ratio for playout on a non 16:9 capable 4:3 monitor.
If making a DVD, you want to encode with the squeezed anamorphic material as the MPEG2 will have an anamorphic flag telling the DVD player to play with the appropriate aspect ratio depending on its settings (related to monitor).
