15mm. I hate it, it's so expensive and I have no idea why the industry standardized on a diameter that isn't used or available. 15mm one ft rods go for $40+...that's insane. Why can we move to a more common standard? Because everything is currently made for 15mm.
If some company started creating equipment that was at a slightly larger but common use standard we could start to move away from 15mm. This could be done by making slip covers with a slot in them which would allow them to cinch 15mm rods while also allowing the larger standard to fit. Of course no one will do this because that would make this custom equipment cheaper to produce.
/end rant/
/end rant/
