thekreative
I've waited a month to post this just to check that they work alright, and they do. I've bought Zacuto zip gear replacement belts.
http://store.zacuto.com/zip-gear-replacement.html
Then I tape them with auto moulding tape ( double sided foam tape.... very sticky). Leaving the backside tape on i measure the lens and cut the belt with a razor blade. I then stick the gear to the lens and then tape over the gear to hold it all in place over night. The great thing about the foam tape is that it holds to the belt tightly but just rolls off the lens if you want it off.
I could see Zacuto stop seling the belts for so cheap after seeing how well this works. With the right measuring I've got all my lenses to fit perfectly all the way around including the joint.
The pictures are of a Contax Zeiss 28 2.8 I just did. I took the pictures to sell the lens it but thought I better post the how-to in the DIY.
