10K Setup?
griffin86
I am considering taking the jump into HD and getting an HVX... However I was interested in seeing what are some possibilities with starting out with a 6k to 10k budget and so on...
I know the absolute necessities are going to include, but aren't limited to: 1.)HVX200, 2.) Some good sticks matched with a decent head (Miller or Cartoni maybe...), 3.) new Laptop (MAC is my way) 4.) some filters (UV, Pro mist etc.) 5.) hopefully a stretch into a 35 mm adapter
I already have some lights and audio setup... any comments, suggestions or recommendations are gladly welcomed...
peace and thanx:kali:
p.s. my uses of the cam will vary from well planned music videos to occasional run-and-gun event shooting so i will also be doubling back to SD every so often
i just budgeted out the following...
HVX200 + 8GB P2 + 2 add'l batteries $5,299.95
8gb P2 $1,099.00
VariZoom VZS1080BP 8" LCD monitor $1,049.50
Brevis HD Imaging Bundle $997.90
Brevis35 Diffuser - CINEFUSE 2* $144.50
Brevis35 Diffuser - CINEFUSE 3 $154.70
Brevis-to-rails mount $114.75
82-72 step down ring $14.96
IndiFocus 18" Rails $129.00
IndiFocus Follow Focus $389.00
Nikon MF lenses 28mm $150.00
Nikon MF lenses 50mm $150.00
Spiderbrace 2 $65.95
Spiderbrace Mini-rig $54.95
Pelican 1650 $209.95
sounds cool... any other suggestions? I am very open to see what kinds of things ppl can come up with... I want to see if there's anything I might miss out (like the indifocus which Zak mentioned), btw, hasanyone got any experience working with the HVX and the Indifocus?
Hi Griffin, I can tell you from first hand experience if you are thinking of the 35mm adapter route make sure you have a good tripod and good head.
Thanks ncje
hmmm... I've had a bit of concern checking heads and tripods. I like the Cartoni focus because it is a true fluid head that seems to match up with what I feel I'd need paired up possibly with some Miller Legs. I was just curious if there were any comparble true fluid heads for less than the same price range? that set will run approx $1,500USD, but I am trying cut that down abit becuase that's a bit rich for my blood at this time...
Any cheaper solutions w/ true fluid head and good weight support for 35mm adapter systems for less than $600?$1000?
peace,
elijah
