Gary Sconce
Now for the lateral suspension stays. Cut four 5/8" tubing stay bases 4" long, grind the bottoms to fit the 1 1/2" rear jib tube.
Drill a 1/4" hole in each as shown. Use the 1/4"-20 bolt threaded into the 1/4"-20 nut so it will align with the hole perfectly and weld on the nut. These will be used to lock in the stays to the 4" long bases of the lateral suspension.
More later!
More later!
