Gary Sconce
***After having fun putting on a two axis head controlled by bicycle parts, I decided it was too much set up. I put on a control bar to the head and use the HYPERCRANE as a huge lockdown rig. We used it all through our feature film shoot for our Horror/Thriller STRICKEN. See post #78 for the current incarnation of the crane. It still works GREAT! -Gary
Follow these instructions and photos and you can build a HyperCrane for your production company. I don't guarantee you can make it for as little as I did, but if you are a good scrounge and have a few hundred bucks you can do it!
I have started a FLICKR account so I will be getting used to posting from it. With the first set I hope to take you from the start to finishing the gimbal, attaching the long rig, putting the jib on the tripod and attaching the weight bar.
Here are some of the things I started with:
100' 1/4" cable, fence gate pulleys (5), screen door pulley wheels (8) numerous cable clamps, ends and attachments, a large zerk fitted caster wheel, three tripod casters with brakes, 90 degree bent plates from strong tie, an old speaker tripod, and a hand weight bar set.
Get two 10' sections of electrical conduit, one 1 1/4" and one 1 1/2" in width and get four 1/2" and three 5/8" eight foot lengths.
Collect assorted metal plate, tube stock and whatever else you can scrounge. I have loads of this stuff. You can gather scrap metal from friends. All metal is good and none should be discarded unless it is too small a piece to use on anything.
These are some of the tools you will need. Notice the pipe cutter in the center... That is a key tool. You will also need a pipe bender that you attach to a water pipe for a lever and stand on to bend the small pipe. Have a load of cut off wheels and don't forget to lubricate the air tools each day.
