macgregor
Hello everyone.
This is a long story. Sorry.
I have a dvx100e. I damaged my lens. I tried to open it and change the lens. Unfortuantely when doing the repair i should burnt some of the electronic boards so the camera no longer could be used. Whenever i attached the battery, a white screen would appear.
I took it to Panasonic. They told me that a board needed to be changed and that it would cost €50. No problem. BUT they also came out with another big failure, they said that one of the data cables of the CCDs unit had been cut (??????). I said that that was impossible.
Well, the cable could not be repaired and the CCDs unit should be changed, at a cost of around €800 (+another €900 of job hours). I answered them that i was not going to pay for something that i had not cut, and asked them to give me the camera back without repairing.
So now i have the dvx100e back. I had to pay for the budget €90. No problem, that is fair.
And how is the dvx100e now? Well, it is partially fixed. Very very strange.
- The lens has been fixed (probably changed) and i did not ask for that.
- The electronic board that had been burnt is fixed, so the camera works perfectly.
- But image from the camera gives bad colors. I think there is one CCD missing (lack of light, and strange colors). THis problems does not occur when playing old tapes.
So what i guess is that in order to make the budget of the problems of the camera they actually repair it (this is common in electronics, in order to know the problem you should fix it first).
They changed the CCD unit itself which is attached to the lens (i guess) and the boards broken too.
And since i told them that i was not going to approve the budget, instead of putting again the old CCDs, they left the new one but broke something so i could not use the new parts (i think this is fair, so i am not complaining about it).
So now i have a camera with new lens, new CCDs, which can play tapes, but which has some CCD cable desconected or something broken.
Today I opened the camera to check if i could see some data cable disconected but everything was in its place.
So here I am writing this long story to see if someone had this same problem or If anyone could give me any advice.
Thanks a lot!
Thanks a lot!
