omnikron
If your running the G2 receiver's 'AF out' setting @ +12dB into a mic level input, you must have the transmitter's 'Sensitivity' set very low. That could account for the high noise floor. I frequently run the G2's AF out set to +12 into line level.
Thanks Rick, I found the problem. Faulty XLR cable. I've been using these for years and I imagine the cable has just gotten damaged. When I switched cables, it took care of the problem. I was also able to do line level in on the Tascam using +12db like you said, however it seems to be just a tad on the weak side when the input volume on the Tascam is all the way up.
I wonder what has a better pre-amp, the Sennheiser receiver or the Tascam DR100mkII.
