idvfilms
600 grit ALOX is bad news. At dvinfo, we started using 1500 grit if I remember correctly, then went to 5 micron, then 3. At this level, on grit charts, we're talking tens of thousands instead of hundreds for grit sizes. You will not get anywhere with 600 grits. Ironically, you will also not get anywhere with sub-1micron grit
This is really important.
Now that we know that it is between 1500 and a 1000 what's the best method you've found for the actual grinding process? how many steps dp you take and ensure that you are getting the best effect possible?
