Ed Kishel
After researching hundreds of posts in an attempt to build my own adapter, I feel I have finally come up with the solution within my technical means. Using the same concept as the G35 and My35, my static adapter is most inspired by the Home Depot 35 from the dvinfo.net alternative imaging forum. It is also found here: http://www.dvxuser.com/V6/showthread.php?t=28055
Starting at the base, it connects to the DVX via a Cokin P series 72mm filter adapter. Mounted to that via set screws (refined from an earlier JB weld attempt) is a 2” male to female PVC adapter. Inside the wide end of the PVC (right before the Cokin) snugly sits a 58mm Macro +10.
Inside the threaded end of the PVC sits the heart of the unit, a Nikon F3 D screen, housed via silicone joints within two 49 mm Tiffen UV filters. This was done to prevent dust from getting to the screen (a big problem with DIY projects). Together the mount and the GG fit into a 2” PVC cleanout cap, which has had a hole cut out of the close end and an Canon FD mount screwed on (again JB weld was too cumbersome).
A Canon SCC 50mm f1.4 sits at the end with a 58mm Fotodiox lens hood to prevent flaring. The whole unit was then sandblasted, primered then coated with a semi gloss epoxy-enamel hammer finish. That was then lightly coated with matte clear coat. The surface is now very tough and resembles the metal finish found on many older Sony Betacams. The interior of the adapter was dusted with a flat black matte finish to reduce any light bounce.
I then created a helpfull workaround to the whole upside down issue by creating a removable mirror that shows the image rightside up. This does not solve the fact it is still backwards, but does help some when framing without a seperate LCD. (see LCD of first picture). Everthing can be found at ebay and home depot. Below is the link to the original design mine is based on, thanks whatever your name is: http://home.comcast.net/~wauhkies/adapter/index.html
I am very pleased with the results, as the Nikon screen works much better than my own ground glass (which had a funky 8mm look to it). I find for static adapters, if you cant handle the wax thing (which I could'nt) this screen has the least grain. With the lens I am using, no hotspots, however I did see a slight hot spot when using a 28mm f2.8. I have found acceptable sharpness considereing how much the image must pass through before it gets to the DVX. Below is some test footage I have shot with it.
http://www.imperialrabbit.com/35MM TEST 2.wmv
Thanks for checking it out!
