myfriendimage
Carbonite Member
I know that all television stations have till like 2007 or something to update to a new broadcasting format, wondering if anyone can shed light on that information I can find it anywhere.
im.thatoneguy said:While that is the mandatory transition time, you *can* switch earlier. Many stations are already in DTV. If you have a satellite or cable TV receiver, it doesn't matter to you, since you're not going to see any change, this only applies to terrestrial radio transmissions.
However, if you have satellite, some receivers (such as the one I have) will decode terrestrial DTV signals for you, and output it to component, S video, composite, DVI etc.. The quality is the same as digital cable, and the reception is either On or Off, usually on and crystal clear, even channels where I used to get unwatchable static. This is one of those cases, where I'm glad the government is giving them a swift kick in the ass to move things along, we've been frequency squatting long enough, and the alternative is much much better.
Another added little bonus is, they can also stream program meta-data, so you can get content titles, and more in an onscreen guide, again just like digital cable.
david_kuznicki said:This "mandatory" date has been continually pushed back. It has caused significant problems for broadcasters across the board.
