Light meter - recommendations?
ahalpert
Major Contributor
i had the cheap one (308) for four thousand years when I shot that wet chemical stuff you cant monitor.
it was fine.
i wonder if there is a phone app? Why? because it is one less bit of kit to pay for and lose and also a well designed phone app would allow you to press save so your photos/readings/TOD were held. useful on recces or sharing with the boss, working with the rental house to see how many lights you need or resetting for a few pickups
I have a Sekonic L-785c that I really like. https://sekonic.com/sekonic-l-758cin...r-light-meter/
But with that said, do you really need one at all? I only use it once or twice a year when testing or evaluating cameras. It has no other use beyond that for me. For electronic cameras, zebras, waveform, false color, etc. are far more informative and useful than a light meter. It just sits in a case 363 days of the year.
If you have a recce.. then the camera may not be with you.. or even setting up the next shot the camera might be on huge sticks or whatever. Thats when I find a meter handy. Once the camera 'has frame' I agree a meter is pontless
Personally I like a DLSR+24-70 photos on a recce. shoot at 50th and all your settings are noted (inmeta data) with a visual reference to each scene, iso, colour temp iris whatever. This shot can be shared and referenced.
They used to sell a smartphone clip-on incident light meter dome called Luxi, but it's discontinued. You can make one with an incident light meter dome glued to a smartphone filter clip adapter, about $20 in parts.
P.S.
This video (starting at 11:39), shows you how to calibrate the cinemeter app to display accurate white balance hue and tint offset.
I often use Adam Wilt's Cine Meter II app. $25 for iPhone and iPad.
Really useful, works with a Luxi diffuser if you want incident metering (and if you can find a Luxi; as Imam says, they're apparently not made any more). For me, a really valuable feature is its reporting color temperature in Kelvin.... I end up in a lot of places with a mix of various lighting conditions. Lab equipment, work lights, overhead lights, maybe a window...maybe tinted windows. Cine Meter lets me know what's going on so I can compensate or choose my hero color temp. You know, I'd like a dedicated photo/cine meter that measures temperature, but I'm not up for paying $1500US for a Scenic C-800-U or something (I'll follow this thread to see if others suggest something to check out.
On scouts, Cadrage (director's viewfinder app), Sun Seeker (solar tracking app), and Cine Meter II really come in handy.
Cine Meter II webpage:
https://www.adamwilt.com/cinemeterii/
Some screenshots from the Apple App Store page:
Cine Meter II.png - Click image for larger version  Name:	Cine Meter II.png Views:	0 Size:	39.1 KB ID:	5709850
Generally speaking the primary use now a days for dedicated light meters is shooting photography with strobes.
anyone doing a recce can be most helped by
'the hallway was 4500k at T2.8 (assuming 1/48 at 800)
then you can work out the needed fixtures
i had a quick spool the app store .. currently It looks like buying the real thing is very on the cards!
Personally the third option is the best.
I hate the touchscreen Sekonics. They are slow to “boot” and are often not that responsive in terms of the touchscreen. They feel cheap to me.
I have the Spectra IV-A but they cost a bit more. But the turn on and meter nearly instantly.
Tried this kelvin meter and screengrab. Now i have a record of the light in my hall - usefull for recces?
My preference would always be for a combo incident/spot meter, as it's so much more convenient than bringing two separate meters along. However, the newer touchscreen Sekonics are pretty awful to use in normal conditions. They have a painfully slow boot time compared to older, mechanical-buttoned options - and pulling out your meter, then having to wait, gets old REAL quick.
I'd have a look if you can find an older L-758 Cine available anywhere (Sekonic's previous flagship combo meter). The UI on those is also pretty awful, but at least it boots instantly.
I've had a Spectra Cine IV and an old Sekonic M for decades, but they come out so rarely. For the type of work I do, my gaffer covers the initial aspect of lighting to a stop I specify using his meter. By the time we are tuning the set, the camera is up and I use a combo of waveform, parade, vectorscope and calibrated monitor to dial things in from there. I also find my intuition is still pretty well "calibrated" from the film days when I relied much more heavily on a meter, so I can judge most exposure levels ratios by eye--sometimes I play the game with my gaffer of guessing a value before he meters it! Although I find this much harder at high ISO's.
I thought about a phone app but I didn't find what I was looking for. I would also wonder about the accuracy. Finally, I'm already using my phone, a tablet, and 2 burner phones for various monitoring and remote control purposes. So I probably wouldn't use one of those. I could buy another burner... but why not just get a dedicated and calibrated device, especially if we're liking the $200 offering.
I don't know if I will end up using it. But I'd like to achieve more regimented and consistent contrast ratios and with faster set-up times on my interviews.
In particular, I did an interview day recently with 4 set-ups that followed a pattern of plenty of time for the 1st set-up; rush to reset for the 2nd set-up; plenty of time for the 3rd; rush for the 4th. I'm not dissatisfied with the results but I think it would help to nail down a consistent look throughout, and to do it in a hurry, if I metered my lighting and locked down my ratios.
Similarly, I did a recent shoot with plenty of time for the main set-up and then 6 quick set-ups (with less lighting) at various locations around a gallery.
I primarily use false color to judge exposure. Light metering would be an additional tool with a different purpose, and also subject-independent.
is a recce a scout?
and is a spool a look?
I hate the touchscreen Sekonics. They are slow to âbootâ and are often not that responsive in terms of the touchscreen. They feel cheap to me.
That's two votes for the 308. Sold! I can see Grug's point about the usefulness of a spot meter, but to some extent false color will do that job.
I like physical light meters a lot (and actually have an older-version 308). But to be redundant, I do find Cine Meter II useful (esp for color temp). OTOH, I share your "not another phone app; sigh" sensibility. OTOOH, the developer says about accuracy:
How accurate is the exposure meter?
With some exceptions, Cine Meter II tracks my other meters (Spectra Pro IV-A and Gossen Starlite) within +/- 1/10 stop from below 1 lux or 0.1 footcandle (about the level of a clear night illuminated by the full moon) to over 100,000 lux or 10,000 footcandles (full sunlight; I’ve measured up to 12,000 footcandles on a sunny day). The exact lower limit depends on the iDevice used, as their low-light limits vary.
The exceptions are:
https://www.adamwilt.com/cinemeterii/faq.html
And he provides clear information about calibration here:
https://www.adamwilt.com/cinemeterii/howto.html
But if you're going to go for a 308, out of the several versions Sekonic makes I'd lean towards the L-308X-U, that's the current version that includes some "cine" features (sorry if this has already been mentioned). https://sekonic.com/sekonic-l-308x-u...e-light-meter/
And if you're not in a hurry and want to save a few bucks, check the Sekonic site for their periodic open-box deals.
Finally, maybe consider getting one of Sekonic's rubber grip/cases for your meter. I got a red one mainly so I can easily spot the thing amongst all my other dark grey and black boxes...and in case I. drop it (again).
https://sekonic.com/sekonic-red-color-grip-for-l-308x/
