CharlesPapert
Director of Photography
Charles' split-screen shot comparison method sounds pretty smart. I'm not sure I'm equipped to do that at present though perhaps I could work it out. It's not an instantaneous solution, though. For a simple 2-4 light set-up, metering your units may not set you back much time.
I have it built into a flight case that generally lives on the cart below, although at times I have pulled out the case and used it standalone because of limited space like on a follow van or in a pre-built monitoring setup.
The primary component is a Blackmagic ATEM Constellation HD switcher, controlled via laptop running the ATEM software. For scopes I use Scopebox, a full customizable standalone app. It's configured to display waveform, RGB parade and vectorscope. I run an outboard portrait-mode computer monitor to display the scopes. I have an OWC hub inside the case to interface the computer via Thunderbolt 3 to the switcher and various USB components. The flight case has a custom patchpanel for connecting sources and monitors.
I have a programmed X-Keys keypad next to the laptop that selects the appropriate camera source (A, B, C or Multiview via a Decimator DMON Quad). Also on this keypad is a button that will take a frame grab, via Scopebox. These grabs show up in a folder within the ATEM software so I just drag them into the framestore from there. At this point I can now call them up as a source via the switcher and can A-B between live image and the grab, do a wipe in any direction, half-dissolve for lining up a matching shot (aka onionskin) or whatever else tickles my fancy.
One could theoretically build out a micro version of this with an ATEM Mini Pro or SDI and an iPad Pro (not sure about how to get the video into the iPad for scopes, haven't tried that one yet). Probably better in that scenario to use a trusty monitor of choice with the built-in scopes, perhaps. I just learned about a pretty cool iOS app called MixEffect that replicates the remote panel control for the switcher with some improvements over the Blackmagic software.
This is a pretty elderly clip running through the capabilities of the system on my big cart, which I only take out on longterm jobs or ones without DIT.
https://vimeo.com/papert/cart?share=copy
The smaller cart that I built a few years later.
the scopes monitor I added after that pic was taken:
