CharlesPapert
Director of Photography
I use live video into my work setup with Scopebox (running into either a Mac Mini for my big cart, or a MBP for my small one) and I can't remember the actual latency at all. Next time I set it up I can test it.
I guess I'm still trying to understand what the actual benefit is of using a MBP as a monitor, other than it's something you are already buying presumably for other purposes. It sounds like you are using it for fairly run-and-gun situations so again, I just think--isn't it a bit weird to have that keyboard hanging out there? Maybe not. I guess with using Resolve like that, you can add whatever LUT is required to true the monitor right there, so not LUT box needed, and you can just toggle between full-screen for monitoring and whatever you need on the interface for setup. If you do this, and you like scopes, you could always add a little inexpensive USB monitor that could swing out to the side that can display the scopes (I wish Resolve offered a bit more flexibility in customizing the position of them, but you can easily dedicate them to the second monitor). I have a setup like that with my lightweight cart:
