QuickHitRecord
I've managed to get this far without ever really using a handheld gimbal for paid work. I've been very comfortable working with dollies, sliders, and cranes. Sometimes I wonder if I'm making life harder than it needs to be, especially with the huge leaps in autofocus as of late. It's clear to see that gimbals have introduced a lot of movement that was never possible before without a crew. In the minus column, it also seems like people are adding motion to every shot, regardless of whether it compliments the scene or not. And they seem like they can be quite fiddly and require large and expensive builds to use properly.
I did use the original Movi on a few low-stakes projects when it first came out. I was amazed by the results. But also remember that it took 30-45 mins to build the thing up and the bulky battery didn't last very long. And then a few years later I spent $700 on a Zhiyun Crane 2, which was getting rave reviews at the time. However, in the handful of test shoots I've done, I've never been able to get a result that I'd be comfortable presenting to a client. With a really wide lens, I could probably follow someone and have it look mostly okay in an almost-handheld kind of way, but that's about all I'd be comfortable with. I'm sure I must not be balancing it properly, despite watching a dozen videos on how to do it.
So I'm curious to know from some actual working pros: Do you use gimbals frequently? And if so, for what kind of work and what crew size? Is bobbing up and down from the operator's footsteps still an issue (even while ninja walking)? Have the newer gimbals gotten to the point that they are pretty idiot-proof (because apparently I am an idiot, at least when it comes to the Crane 2)? Are there alternatives to gimbals that you prefer?
