I'll be honest, in almost 25 years of doing this professionally, I've never had anyone, director or otherwise, seriously tell me to tilt in degrees. I also don't recall ever shooting with a head designed for motion(Vinten, Sachtler, O'connor, Cartoni, Miller, etc.) that had witness marks for the tilt in degrees.
But what I HAVE had way too much of, is people that have been in this business for decades and SHOULD know better, telling me to PAN UP or PAN DOWN.
How are you supposed to write tilt angles in degrees? For example, if the camera points down, do you write 85 degrees or -5 degrees? Thanks.
I think it's more for VFX work, I've seen DPs on huge green screen shoots make notes of their angles. I assume this would be more common than being told to tilt a certain angle in advance, unless matching other material.
IDK how the highest level productions do it (would be cool if that was just Arri metatdata) but a simple phone app, flush with the camera, gave accurate enough readings and was the extent of the tech from what I've seen.
I'm not saying SJX is doing VFX work, just mentioning a situation where it could be important.
Also, what are you shooting!?
I will echo the above. Positive numbers above horizontal, negative below. And referring to tilt in degrees is generally for repeatability, as also noted. Did that on Friday with an effects bit that we shot the backplate for two weeks ago. The AC's logged height, focal length, distance and tilt measurement and we were thus able to recreate the foreground.
For regular shooting I am more likely to refer to pan in degrees when describing a shot as that comes up more often, i.e. if describing a shot that is going to be set up before I get there I may see "give yourself 25 degrees off center either direction" to indicate how much of the world we are going to see so gear doesn't get placed there, Tilt descriptions would probably be limited to 90 degrees, i.e. straight down requiring camera offset to not see the dolly, or possibly 45 degrees to indicate that such a setup is NOT needed. I wouldn't give an operator directions in degrees in terms of operating a shot on a regular basis.
Charles, what method or device did they use to measure the tilt?
But what about a 5 degrees tilt down? I would think -5°. But in 3D software for example you need to use 85° for some reason.
These days I pretty much only see iPhones used for tilt measurement.
Very interesting. I thought for sure they'd be using something specially made for film production. Thanks for the info.
