Hi everyone,
I'm new to the P2 workflow and to this user group. I have 2 HPX 170's, a P2 Gear, 4 32GB cards, 2 16GB cards. I'm editing on an Intel Mac, FCP 6 and have a few questions.
1. While at a P2 workflow seminar I thought the lecturer explained that you could offload the cards in the field with a Macbook Pro and two drives at the same time, then one drive can be use as a edit drive and the other becomes a backup. How do I setup this process?
2. When using the workflow described in this forum on "Proper P2 Offloading Procedure for a Mac", posted by Barry, I noticed that the "lastclip.txt" file does not copy to the hard drive, I haven't had any problems editing, but could this cause me problems down the road, or am I doing something wrong?
3. I have so far uploaded Metadata before I shoot, then use the P2CMS software to offload the cards and log and transfer to import shots into FCP. When I do this I see the Metadata in the P2CMS software, but when I import thru log and transfer the metadata does not show up. Am I doing something wrong? Is there a better way to maintain the metadata?
4. How do I change the volume names of each of my cards so that when they mount on the Mac the cards have a unique name instead of each having "No Name"?
5. When recording long form, I upload metadata before the shoot. When I have to hot swap a card. Do all cards have to be preloaded with the same metadata or does the metadata carry over from the previous card and if I do preload all the cards does the auto numbering of the clips just pick up where the previous card left off?
I apologize for writing a novel here, but it seem that no matter how much prep you do to change formats, once you actually get your hands on the equipment it always brings up more questions than answers.
Thanks in advance for your response.
Wayne
Wayne
