How the heck do you delete MXF Files from OSX?
Kholi
Section Moderator
Damned locked majiggers. I totally forgot how to get rid of them! Can anyone tell me hows?
No worky. Says "this file is locked"
it's trying to delete them before they even hit the trash, but the MXF's being locked won't allow it. =T
if you have any app. like quicktime, fcp, p2log, etc. that has opened any of them, you may have to quit the apps first...
That's not it. It's saying that the files are locked, which they always are as far as MXF files are concerned.
Like, copy an MXF file to your desktop then try to throw it in the trash.
I second what Tom says about holding down the "option" key while emptying the trash. That's the only way I've been able to do it without unlocking each individual file.
Best,
Andy
I can't even unlock them. I mean I go to unlock, change permissions, but it stays locked. it's so confusing.
And when I trash them it has to actually delete them because they're in excess of 1GB file sizes.
Grrr.
Kholi,
Where you logged in in the same as the same user that copied the files over? since the files are locked and you can't unlock them then there are two possibilities that spring to my mind:
A. You don't have permission to unlock the files because they where created with a different user account.
or
B. The permissions for the file have become corrupt/messed up. This is an easy fix, you can use Disc Utility in your applications/utility folder to repair/verify any drive that is not your system drive. If you have your files on your system drive then simply boot up your original OSX Disc. (I think you hold down C as it boots up) then use Disc Utility to verify/repair your drive.
Here is a document from apple that might help:
http://support.apple.com/kb/HT1526
I hade some poblems with this for time to time. As said before, it seams to work less good if you have open any finder window and maby aplication windows. I think its the option key shortcut that gets confused. Aslo try reboot one time if nothing helps. In worst scenario you can go throw all the files and uncheck write protected. Good luck!
I use this process often as the option + empty trash doesnt work for me either:
taken from apple support
Advanced tip about deleting locked files
If there are several locked files in the Trash, you can unlock them all at the same time at the command line. Follow these steps:
  1. Open Terminal. It's located in /Applications/Utilities.
    Type: chflags -R nouchg
    Note: Type one space (not pictured) after nouchg in the line above, so that it ends in "nouchg ". Do not press Return yet.
  2. Double-click the Trash icon in the Dock to reveal the contents of the Trash. If necessary, arrange the Finder window so that a portion of the Terminal window is still visible.
  3. Press the Command-A key combination to select all files in the Trash.
  4. Drag the files from the Trash to the Terminal window.
    Note: This automatically enters the pathname for each file. This eliminates the need to individually empty multiple Trash directories, particularly when multiple disks or volumes are present.
  5. Press Return. No special text message will be shown indicating that the command was successful.
  6. Empty the Trash.
